Root [Boost Mobile] need more help here
I notice sometimes certain folders don't like to be copied into. Anywhere in /data seems to be agreeable, though. You can even make your own subdirectory in it for your music, if you like.
Trying to copy from SD card to my internal memory
Use es to navigate to the /data folder, press menu key and select new folder and name it whatever you want. After creating the folder long press it and select permissions make sure user is enabled to read, write and execute. You should now be able to copy files to that folder.
one more thing just noticed that it doesnt play in my power amp... do i only have to use es media player???
Most media players only scan your SD card. The one you're using most likely does this, making it not see what you have on your internal memory.
