***USE AT YOUR OWN RISK***
***WARNING, do not use if your phone has KNOX***
If you are looking for a odin backup with the OTA update MG2 go to this thread: ODIN Backup for --> SPH-L710_MG2
ODIN Backup for --> BOOST MOBILE SPH-L710_MD7 stock
this is a stock odin backup for SPH-L710_MD7 (stock system-boot-recovery)
data and cache is not backed up so as soon as you can you will have to clear dalvik cache, cache, and data --- or just do a factory reset.
Extract the 7-Zip file
use Odin3 v3.07
put in pda slot only!
uncheck auto reboot
connect your phone
when properly connected (if you dont know -- dont use)
press start
when finished pull battery
enter recovery
factory reset
reboot to system
you know should be stock
i noticed i was rooted when making this backup. i was about to make a new one when i though i should leave it so you can reset your flash count after flashing stock (triangle away needs root). so weather you want to keep root or remove root you will have to install SuperSU from the market.
TO REMOVE ROOT:
i suggest running triangle away before you unroot
install SuperSU
Grant root permission
open SuperSU
goto settings
scroll all the way down
press "Full unroot"
after it reboots you will be unrooted
First 2 are compilings from actual phones
system is based on my origanal backup, stock recovery,
boot.img is from Back to stock 4.1.2
TESTED AND WORKING
recovery / boot.img (kernel)
pda--SPH-L710_MD7-my-stock_boot-recovery.tar --- Will take 10-15 seconds to flash
TESTED AND WORKING - has static powered off charging screen
rooted system / recovery / boot.img (kernel)
this is the one that i was able to take the OTA update
Download Via ( MEGA | MediaFire ) --- Will take 10-15 minutes to flash
below is from Kies firmware (from post #28)
TESTED AND WORKING
Download Via ( MEGA | MediaFire )--- Will take 10-15 minutes to flash
I HAVE NOT TESTED (from Kies firmware) (from post #28)
ENTIRE STOCK PHONE (***USE EXTRA CAUTION it flashes a lot of partitions!!!***)
aboot/boot/cache/NON-HLOS/persist/recovery/rpm/sbl1/sbl2/sbl3/system/tz
Download Via ( MEGA | MediaFire ) --- Will take 15-20 minutes to flash
Boost Mobile S3 PIT file for Odin
if you need to re-partition you phone, add this file to Odin
click "PIT" navigate to this file
check "Re-Partition"
click "PDA" navagate to the proper PDA-.TAR file
here is the 'Boost Mobile S3' PIT file: download via (MEGA | MediaFire)
and here is the contents of the PIT file in a human readable fashion
Entry Count: 28
Unknown 1: 1598902083
Unknown 2: 844251476
Unknown 3: 21325
Unknown 4: 14413
Unknown 5: 13881
Unknown 6: 48
Unknown 7: 0
Unknown 8: 0
--- Entry #0 ---
Binary Type: 0 (AP)
Device Type: 2 (MMC)
Identifier: 1
Attributes: 5 (Read/Write)
Update Attributes: 1 (FOTA)
Partition Block Size/Offset: 8192
Partition Block Count: 122880
File Offset (Obsolete): 0
File Size (Obsolete): 0
Partition Name: MODEM
Flash Filename: NON-HLOS.bin
FOTA Filename:
--- Entry #1 ---
Binary Type: 0 (AP)
Identifier: 2
Partition Block Size/Offset: 131072
Partition Block Count: 256
Partition Name: SBL1
Flash Filename: sbl1.mbn
FOTA Filename:
--- Entry #2 ---
Binary Type: 0 (AP)
Identifier: 3
Partition Block Size/Offset: 131328
Partition Block Count: 512
Partition Name: SBL2
Flash Filename: sbl2.mbn
FOTA Filename:
--- Entry #3 ---
Binary Type: 0 (AP)
Identifier: 4
Partition Block Size/Offset: 131840
Partition Block Count: 1024
Partition Name: SBL3
Flash Filename: sbl3.mbn
FOTA Filename:
--- Entry #4 ---
Binary Type: 0 (AP)
Identifier: 5
Partition Block Size/Offset: 132864
Partition Block Count: 4096
Partition Name: ABOOT
Flash Filename: aboot.mbn
FOTA Filename:
--- Entry #5 ---
Binary Type: 0 (AP)
Identifier: 6
Partition Block Size/Offset: 136960
Partition Name: RPM
Flash Filename: rpm.mbn
FOTA Filename:
--- Entry #6 ---
Binary Type: 0 (AP)
Identifier: 7
Partition Block Size/Offset: 137984
Partition Block Count: 20480
Partition Name: BOOT
Flash Filename: boot.img
FOTA Filename:
--- Entry #7 ---
Binary Type: 0 (AP)
Identifier: 8
Partition Block Size/Offset: 158464
Partition Name: TZ
Flash Filename: tz.mbn
FOTA Filename:
--- Entry #8 ---
Binary Type: 0 (AP)
Identifier: 9
Partition Block Size/Offset: 159488
Partition Name: PAD
Flash Filename:
FOTA Filename:
--- Entry #9 ---
Binary Type: 0 (AP)
Identifier: 10
Partition Block Size/Offset: 160512
Partition Name: PARAM
Flash Filename:
FOTA Filename:
--- Entry #10 ---
Binary Type: 0 (AP)
Identifier: 11
Update Attributes: 5 (FOTA)
Partition Block Size/Offset: 180992
Partition Block Count: 27904
Partition Name: EFS
Flash Filename: efs.img.ext4
FOTA Filename:
--- Entry #11 ---
Binary Type: 0 (AP)
Identifier: 12
Partition Block Size/Offset: 208896
Partition Block Count: 6144
Partition Name: MODEMST1
Flash Filename: nvrebuild1.bin
FOTA Filename:
--- Entry #12 ---
Binary Type: 0 (AP)
Identifier: 13
Partition Block Size/Offset: 215040
Partition Name: MODEMST2
Flash Filename: nvrebuild2.bin
FOTA Filename:
--- Entry #13 ---
Binary Type: 0 (AP)
Identifier: 14
Partition Block Size/Offset: 221184
Partition Block Count: 3072000
Partition Name: SYSTEM
Flash Filename: system.img.ext4
FOTA Filename:
--- Entry #14 ---
Binary Type: 0 (AP)
Identifier: 15
Partition Block Size/Offset: 3293184
Partition Block Count: 25624576
Partition Name: USERDATA
Flash Filename: userdata.img.ext4
FOTA Filename:
--- Entry #15 ---
Binary Type: 0 (AP)
Identifier: 16
Partition Block Size/Offset: 28917760
Partition Block Count: 16384
Partition Name: PERSIST
Flash Filename: persist.img.ext4
FOTA Filename:
--- Entry #16 ---
Binary Type: 0 (AP)
Identifier: 17
Partition Block Size/Offset: 28934144
Partition Block Count: 1720320
Partition Name: CACHE
Flash Filename: cache.img.ext4
FOTA Filename:
--- Entry #17 ---
Binary Type: 0 (AP)
Identifier: 18
Partition Block Size/Offset: 30654464
Partition Name: RECOVERY
Flash Filename: recovery.img
FOTA Filename:
--- Entry #18 ---
Binary Type: 0 (AP)
Identifier: 19
Partition Block Size/Offset: 30674944
Partition Name: FOTA
Flash Filename:
FOTA Filename:
--- Entry #19 ---
Binary Type: 0 (AP)
Identifier: 20
Partition Block Size/Offset: 30695424
Partition Block Count: 40960
Partition Name: CARRIER
Flash Filename: carrier.img.ext4
FOTA Filename:
--- Entry #20 ---
Binary Type: 0 (AP)
Identifier: 21
Partition Block Size/Offset: 30736384
Partition Name: BACKUP
Flash Filename:
FOTA Filename:
--- Entry #21 ---
Binary Type: 0 (AP)
Identifier: 22
Partition Block Size/Offset: 30748672
Partition Name: FSG
Flash Filename:
FOTA Filename:
--- Entry #22 ---
Binary Type: 0 (AP)
Identifier: 23
Partition Block Size/Offset: 30754816
Partition Name: SSD
Flash Filename:
FOTA Filename:
--- Entry #23 ---
Binary Type: 0 (AP)
Identifier: 24
Partition Block Size/Offset: 30754832
Partition Block Count: 10240
Partition Name: GROW
Flash Filename:
FOTA Filename:
--- Entry #24 ---
Binary Type: 0 (AP)
Identifier: 70
Partition Block Size/Offset: 0
Partition Block Count: 34
Partition Name: PGPT
Flash Filename: pgpt.img
FOTA Filename:
--- Entry #25 ---
Binary Type: 0 (AP)
Identifier: 71
Partition Block Size/Offset: 34
Partition Name: PIT
Flash Filename: MSM8960.pit
FOTA Filename:
--- Entry #26 ---
Binary Type: 0 (AP)
Identifier: 72
Partition Block Size/Offset: 50
Partition Block Count: 32
Partition Name: MD5
Flash Filename: md5.img
FOTA Filename:
--- Entry #27 ---
Binary Type: 0 (AP)
Identifier: 73
Partition Block Size/Offset: 30777311
Partition Block Count: 33
Partition Name: SGPT
Flash Filename: sgpt.img
FOTA Filename:
Unknown 3: 21325
Unknown 4: 14413
Unknown 5: 13881
Unknown 6: 48
Unknown 7: 0
Unknown 8: 0
--- Entry #0 ---
Binary Type: 0 (AP)
Identifier: 1
FOTA Filename:
--- Entry #1 ---
Binary Type: 0 (AP)
Identifier: 2
FOTA Filename:
--- Entry #2 ---
Binary Type: 0 (AP)
Identifier: 3
FOTA Filename:
--- Entry #3 ---
Binary Type: 0 (AP)
Identifier: 4
FOTA Filename:
--- Entry #4 ---
Binary Type: 0 (AP)
Identifier: 5
FOTA Filename:
--- Entry #5 ---
Binary Type: 0 (AP)
Identifier: 6
Partition Name: RPM
FOTA Filename:
--- Entry #6 ---
Binary Type: 0 (AP)
Identifier: 7
FOTA Filename:
--- Entry #7 ---
Binary Type: 0 (AP)
Identifier: 8
Partition Name: TZ
FOTA Filename:
--- Entry #8 ---
Binary Type: 0 (AP)
Identifier: 9
Partition Name: PAD
Flash Filename:
FOTA Filename:
--- Entry #9 ---
Binary Type: 0 (AP)
Identifier: 10
Flash Filename:
FOTA Filename:
--- Entry #10 ---
Binary Type: 0 (AP)
Identifier: 11
Partition Name: EFS
FOTA Filename:
--- Entry #11 ---
Binary Type: 0 (AP)
Identifier: 12
FOTA Filename:
--- Entry #12 ---
Binary Type: 0 (AP)
Identifier: 13
FOTA Filename:
--- Entry #13 ---
Binary Type: 0 (AP)
Identifier: 14
FOTA Filename:
--- Entry #14 ---
Binary Type: 0 (AP)
Identifier: 15
FOTA Filename:
--- Entry #15 ---
Binary Type: 0 (AP)
Identifier: 16
FOTA Filename:
--- Entry #16 ---
Binary Type: 0 (AP)
Identifier: 17
FOTA Filename:
--- Entry #17 ---
Binary Type: 0 (AP)
Identifier: 18
FOTA Filename:
--- Entry #18 ---
Binary Type: 0 (AP)
Identifier: 19
Flash Filename:
FOTA Filename:
--- Entry #19 ---
Binary Type: 0 (AP)
Identifier: 20
FOTA Filename:
--- Entry #20 ---
Binary Type: 0 (AP)
Identifier: 21
Flash Filename:
FOTA Filename:
--- Entry #21 ---
Binary Type: 0 (AP)
Identifier: 22
Partition Name: FSG
Flash Filename:
FOTA Filename:
--- Entry #22 ---
Binary Type: 0 (AP)
Identifier: 23
Partition Name: SSD
Flash Filename:
FOTA Filename:
--- Entry #23 ---
Binary Type: 0 (AP)
Identifier: 24
Flash Filename:
FOTA Filename:
--- Entry #24 ---
Binary Type: 0 (AP)
Identifier: 70
FOTA Filename:
--- Entry #25 ---
Binary Type: 0 (AP)
Identifier: 71
Partition Name: PIT
FOTA Filename:
--- Entry #26 ---
Binary Type: 0 (AP)
Identifier: 72
Partition Name: MD5
FOTA Filename:
--- Entry #27 ---
Binary Type: 0 (AP)
Identifier: 73
FOTA Filename:
GL
BIG THANKS to Stlouizsin for risking his phone to test
