Root [Boost Mobile] Original Stock Kernel
iram
Would anyone have the original Stock Kernel that came with Warp and instructions on how to revert back to it from Alien Kernel
Thank you
Are you looking for just the kernel or a quick and easy return to stock kernel and rom? Check the first sticky thread... I don't know of a stock flashable kernel only...
Hope I termed all properly.....My warp is rooted with Alien kernel but I still have stock ROM I just need to get back to original kernel....As discussed in a different post I beleive the Alien kernel may have disabled the Hearing Aide compatability function....The only way I think to verify that is to get back to original kernel that came with phone to test it.
Thank you
Here you go!
So far as instructions, all you should need to do is reboot into your custom recovery, then flash this kernel. I've personally never used it, as I've never needed to, and it should work just fine, however a cautionary backup is always recommended.
