Hello and welcome to the forums. I see you having trouble with a android device . Looks like a question on rooting with cm10. Well to get the play store to work you will need to get the latest Gapp. Yes the latest G app will provide you with gmail and vender app which is the playstore and more.
You can also find this if you download a app called goo inside. Once you get the latest gapps this app called goo inside will keep the gapps up to date and also show if your current rom has a update . Goo.inside . Check it out in the playstore.
