Root [Boost Mobile] Problems and EXT4
anmire
First of all, just gotta say that the HaloJelly 5 point two rom is awesome *as-is*, and not said lightly either. However, I did notice a couple things. One, download speeds on WOEM are way better and less sketchy/finicky for some reason, especially when dealing with google play...is that an issue with the b10g base or proxies or...?? And two, flashing off of the rom makes it nearly impossible for me to flash a different one. Any help would be awesome.
I'm thinking that the fact that my sd card's EXT4 is unmountable and unformattable has something to do with it...that or some funky problem between deep tweaks on woem and HJ.
The phone goes through the entire flashing process perfectly fine, but on boot, it stops at the Alien Kernel logo. Any ideas anyone?? I've been mulling and will keep mulling about it.
They both use Alien Kernel, but it could either be a bad download (you can test for packet loss at pingtest.net), or it could be HaloBean 5... I've never had the issue though, I switched between HaloBean and CM10 a couple of times a few days ago... it could also be your recovery.
I've unfortunately already tried the super wipe...maybe i'll just wipe everything like 6 times hahaha
