http://db.tt/hUBmmdR5......
Flash in cwm or extract and pull apk frim /system/app folder
The Camera Keeps Foce Closeing
How did you install it? If you flashed it you shouldnt have a problem.. my guesd is you moved the app to your /system/app folder and forgot to set perms to rw-r--r-- and reboot when you did. Thats my guess.. i could be wrong
Flashed it and no good keeps force closing
I need it
Another dependency is the system camera sounds. I heard (from a post by Mr. Bobo, I think) that if the sounds are renamed or deleted the camera also won't start.
