Root [Boost Mobile] [Resolved]
does anyone have the links for the oc kernel and the cwm with data restore fixed in flashable zips? thread ref?
help appreciated :)
[EDIT] found oc kernel here Windows Phone 7 ROM Ver 3.1.0P2 {*UPDATED* 6/19/12} - Android Forums.. still need a cwm recovery zip with data :confused:
the latest cwm came from hroark: http://db.tt/DOYkJJns
the data fix wasn't a problem with cwm, it was a flashable zip to correct a file in the stock ROM that caused data to get wiped during restore, you have to flash this file once on a ROM before doing a backup to get your data to come through during a restore from cwm: http://db.tt/uq6zPLcl
Most ROMS have the data fix built in already, mine does (n00b ROM) as do most others I have tried.
Thank you for clarifying.
I'm already running your rom so I guess I was good to go without knowing it!
The help is greatly appreciated, you're awesome :)
