Root [Boost Mobile] ROM installation problems
zr0w69
Member
Is there a factory reset or backup incase I want to go back to the factory settings and rom?? I wanna install this rom but i need to know im safe if something goes wrong. anyone help me with this?
Before you u install do a back up with cwm,then you can use that to flash back
im having serious issues... when i put either rc1 or rc2 on, as soon as my phone goes to the lock screen it wont unlock, its just a back screen. THEN, after putting on rc1 i tried to put the stock rom back on and it gave me the same MD5 error again, i really need help here!!!
I dont wanna clutter up this post,search, theres a fix by hroark
rc1 or rc2 of cwm are not latestone, you need:
http://androidforums.com/warp-all-t...cussion-development-cm7-only.html#post4118759
and the fix for data restore issue & some black sreen problems:
Wait, since when are we updating to clockworkmods that haven't been announced in any special threads yet?
Derp, it's in a pretty obvious place but I would never have looked there...
