Root [Boost Mobile] ROM's confirmed working for SPH-L710T
cartersball
I've seen a few people ask in the main thread for this device model which ROM's are confirmed working. As a work in progress I'd like to list them here, as well as any special flashing instructions for this model. I'll update this list as we grow, and begin to provide links to each ROM and any special instructions. Any and all help will be appreciated in gathering the links and instructions. If you have confirmed a working ROM and setup please list so I can test.
As always, please be sure to thank or donate to the ROM developers for each of these in their respective threads. Devs work for free in their own free time to bring us these goodies for the pure and simple joy of creating.
NOTE: ROM FLASHING IS DANGEROUS AND COULD POTENTIALLY BRICK YOUR DEVICE IF DONE INCORRECTLY. I ASSUME NO RESPONSIBILITY FOR YOUR DEVICE IN POSTING THESE WORKING ROMS.
To date I have confirmed working the following ROM's:
Touchwiz ROM's
Wicked S5 Xperience
http://forum.xda-developers.com/showthread.php?t=2983340
Wicked X 8.0 Barebones
http://forum.xda-developers.com/showthread.php?t=2750674
Tribute ROM
http://forum.xda-developers.com/showthread.php?t=2768483
Conquest Singularity
http://androidforums.com/index.php?threads/850787/
To install the Touchwiz ROM's listed above follow these custom ROM flashing instructions courtesy of 6th_Hockage.
Almost any custom ND8 TW Rom will install with the Updated Kernel on the SPH-L710T...but if you have been rom hopping like yours truly you will have to:
1. Odin the Stock NF4
2. Odin PhilZ latest recovery
3. Boot into said recovery
4. Choose wipe to install new rom
5. Flash an ND8 based TW Rom
6. Flash updated Kernel
7. Flash Boost or Virgin APN Fix (if on Sprint skip this)
8. Reboot and profit
Updated Kernel For TW only
https://www.dropbox.com/s/g4pqnnaw7f7izx9/KT747-TW-KK-4.4-ATT-05-13-2014.zip?dl=0
APN fixes work for both TW and AOSP ROMS
Boost: https://www.dropbox.com/s/vdmn9iiv1w1i5v8/Universal_Boost_APN_Fix-R2.zip?dl=0
Virgin: https://www.dropbox.com/s/16j9oqmnubf4trv/Universal_vmu_ApnFix-v.R2.zip?dl=0
AOSP ROM's
CM 11 Snapshot M10
http://androidforums.com/index.php?posts/6878682
Liquid Smooth 4.0- use d2bst version
http://forum.xda-developers.com/showthread.php?t=2958917
MIUI V5
http://forum.xda-developers.com/showthread.php?p=45541141
Candy Kat
http://forum.xda-developers.com/showthread.php?p=50056287
OctOS- use d2bst version
http://forum.xda-developers.com/showthread.php?p=58923170
Thanks to decimalman we have an AOSP kernel with rotation working correctly!!
http://forum.xda-developers.com/showthread.php?t=2174403
Custom Mods
Splash screens by 6th_Hockage
http://forum.xda-developers.com/showthread.php?t=2810741
Added to the OP thank you! Have you flashed some other ND8 based ROM's we can add to the list?
Yes and i will list them :) just if you want to use them you have to follow my instructions that i linked to earlier for TouchWiz ND8 custom roms
Wicked X 8.0/Bare Bones http://forum.xda-developers.com/showthread.php?t=2750674 i personally flashed the Bare Bones version
Tribute Rom http://forum.xda-developers.com/showthread.php?t=2768483
Also could you add this to the thread it's my icing on the cake http://forum.xda-developers.com/gal...custom-touchwiz-splash-screen-sprint-t2810741 <---- my custom splash screens :)
Thanks! I'll get this added to the OP, as well as links to the kernel and APN fixes.
Speaking of the kernel, I know this fixes our rotation issue but I still seen to have rotation issues with videos in landscape mode. Take YouTube for example, every time I turn the phone on it's side the video is upside down. Anyone else having this issue?
So should i wait for a sprint apn fix or something like that before i try any of these? Anyway though i appreciate you posting for this model.
Yep that's the kernel I'm using. Must have been a bad flash because I've flashed it again and the issue had been resolved
You shouldn't need an APN fix for Sprint that I know of.
Apparently users of the Sprint variant of this phone require a fix cause they only get 3g max on any ND8 rom/AOSP rom i have supplied a fix but i have no idea if it worked for the person i sent it to
I think u mentioned an apn fix backing up stock and then restoring it on another rom but i could not get a backup from stock as i think the apns cannot be backed up on kitkat 4.4.x
I looked at the script more closely and it actually didn't even install the apns, just removed the telephony.db. Weird.
I made a new recovery zip that replaces the apns (with n.sprpre.ispsn), extracts them to system and deletes the telephony.db. This brought LTE right away to CM11 M10.
It worked perfectly in MIUI though too.
It allowed LiquidSmooth to connect to LTE but it didn't allow a data connection. Couldn't really check what went wrong since LiquidSmooth APN settings are just broken. I'll test again once there's a new build of LiquidSmooth.
Here it is: https://drive.google.com/file/d/0Bze1kOAjEQyoX05iVC1VNl9IdFE/view?usp=sharing
