Hmm. Torch works for me on sprint. Is that a known quirk when using the sprint Roms?
i lied, it does work... the widgit is what i tried to use... it dont work until you activate the app first
downloading moar as we speak. hopefully flash tonight
well I'm out in the field today running around trying to find a dollar.. running the carbon rom, this baby is sweet, runs rather nice... 4G does not work and it seems like the GPS is not using the actual GPS but triangulated from the towers and always off by hundred yards to 500 yards... so bad GPS kills it for me... back to the moar ROM
Did you flash the piggyback zip?
Assuming its the sprint ROM
Get.cm/d2spr
I personally prefer carbon ROM
yep sure did like 4 or 5 different times
Hey is carbon rom more stable the cm 10.2 looking at the change log it seems to be better
carbon seems great, no fc's, nice and smoothHey is carbon rom more stable the cm 10.2 looking at the change log it seems to be better
carbon seems great, no fc's, nice and smooth...
just could not get 4g to work, and gps does work just was not precise like i need for my job. mms does work, however with very poor cell service its basically obsolete, compared to normal stock which would take 10-40 mins to send myself a pick
but if 4g is not a must have, it is a great rom
I prefer it to CM. One main thing that's bugs me a LOT is when I'm listening to music with headphones and get a call, the phone rings through the normal speakers and not through the headphones. So annoying :banghead:
Carbon works right
They're all stable enough for daily drivers, cm just has those random bugs that hamper usability for me
yup...Oh no 4g is a must have i paid for it I'm using it lol did you try manually configuring your apn?
yup...
APN: Boost_Mobile
Proxy:
Port:
User Name: Boost_Mobile
Password:
Server:
MMSC: http://mm.myboostmobile.com
MMS Proxy: 68.28.31.7
MMS Port: 80
MCC: 310
MNC: 00
APN Type:
typed all that in.... did piggyback.zip four or five times.... did the apn restore from the app trick....
im sure there is a way, was going to mess with it some more tonight, but was out in the field and gps was not on spot, so i had to restore moar
