carnivalrejectq
Member
Just bOught this phone today. Two questions here. Can someone direct me to a thread maybe for rooting the triband version in the first place?
DOWNLOAD ODIN HEREJust bOught this phone today. Two questions here. Can someone direct me to a thread maybe for rooting the triband version in the first place?
Oh boy lol sweeeeeeet can't wait.It is almost Xmas I feel like a kid again.Everyone check out the bottom of OP HUGE NEWS
Ok first off i love you guys for providing help with this l710t. I also somehow screwed up my partitions and am afraid of playing with it to figure it out. Can someone walk me through repairing them?![]()
Download mode works fine. Phone works but apps like BitTorrent say No such directory both for my external sd and locations like /storage/emulated/legacy/download
also when i use philz recovery and click "clean to install new rom" it says...
"E: Unknown volume for path (sd-ext)"
Did you download and run these apps like it says on OP? This is the part I mean:
*In order to fix the write-to-sd issue download the KitKat Fix on playstore as well as the one called Int-SDCard Write Fix (green little android holding sd card). Run those both separately and restart separately and that will fix it.
They saved me from a headache I had trying to figure out why Titanium Backup kept telling me "Insufficient Space. Back-up failed."
There is a thread in this section that explains that. I'm not sure which one it is you can search for it.Also how good are your boost mobile data speeds before and/or after throttling? And has anyone figured out how to bypass boost mobile data throttling? Before I get throttled i can only clock like 100-150kbps on lte and after I get throttled my speeds are only like 10-20kbps still on lte. Can someone help me get normal data speeds?
Thank you very much. The int-sdcard write fix app corrected my torrent problem but in recovery it still says unkown volume for /sd-ext/ can anyone tell me what that means or if it matters?
Everything works if ya do it rite,what you trying to do?Does this work?
Anyone have positive results with the proxies at 0
