Root [Boost Mobile] Stings Blue Rom
stingrays
Im a day late so I apologize:D. First all i would like to thank Hroark.. Used your meta inf permissions. Made this easier. So here is the Blue Rom, Everything stock. Font change to Droid. Just a different color scheme and small changes. Enjoy! This is a BO8c, No Launchers or overlays.
Update. Added CWM and root
Put file in clockwork, As IS.. backup,
Make a back up copy (CWM)
reset to factory
clear cache
advanced, clear Dav
Install form Zip
Clockwork- backup
Install Blueromupdate.zip
:D:D:D:D:D:D:D:D:D:D
http://www.mediafire.com/?nv7b137j1dcch37
Icon Changes. Bat icon. Usb icon to blue, Download bar blue. Next version will have the signal bars changed.
V2
http://www.mediafire.com/?bcyt8brea7j8pdc
My bad, should have included that in the rom.... made the changes in the description. Thanks for pointing that out.. lol.. got in a hurry and forgot.
so im going to loose root if i use this rom??
Not anymore. Sting updated it to include Root and CWM.
Sting I've been running your rom for a few days now and I'm having no problems. My fav color is blue so I love it. Keep up the good work. Obliged!!!
Edit: Just installed V2 and you will need to root your phone after the install.
Love the rom but it would have been nice to change everything blue for example the browser messanging logo any changing on that???
Made the changes for a couple of icons. Download link will be under the old version up top. :cool:
I would like to add Live wallpapers to this rom.... but ive gone through what i know and none work.... anyone help me out here please?????:(
