rootinghaven
Not true I have been running it for 5days no trouble I'm using the latest philz to flash WiFi works so try againconquest has issues with rotation
as well as wifi and sometimes camera
i bet the md5 didn't matchNot true I have been running it for 5days no trouble I'm using the latest philz to flash WiFi works so try again
I been help out but u don't see itTROLL::::: you have not contributed to not one bit of help in this thread... all you do is contradict people if you dont need help or have help to give go somewhere else
It does match I show ui bet the md5 didn't match
Okay guys I have it ready mind you I used this on my boost version and worked fine for me just make a back up just in case. Also make sure the MD5 matches and that you use the latest PhilZ recovery cause that's the one I used link: https://www.androidfilehost.com/?fid=95832962473400340
U need to use the latest philz I put on my dropxbox bc by getting that tar file is better flash it philz they uploaded isn't great that was the big issue I never had no problems with the ROM or kernelSorry i meant the other persons that you quoted, since you have it working while he doesn't
thank you i am now running stock.If you have to change the extension from .md5 to .tar as well and it's not just something with how dcutz was doing it, let me know so I can reupload it. Even if it appears to work, if you get an error while loading it to odin (I didn't) something is slightly off with the file.
i made a zip to convert the Odexed stock rom to De-Odex since the stock rom comes with the extra Odex files...Hu..?
Not true I'm using Apollo music player with viper4droidalso ViPER4Android works as long as you have the stock music player and Google Play music plus every time you reboot the first player you choose won't get the Viper boost but the second one you open will... or at least for me that's how it works...
I'm using touchwz kernelBut you're using a non-stock kernel on the conquest ROM, not the stock ROM which I believe he was referring to.
My conquest isn't beta so many noobs don't know how to flash a ROM or kernelflashed the latest conquest beta and rotation is f'd up https://www.androidfilehost.com/?w=files&flid=15185
I'm no noob when it comes to conquest cause i used it when it first came out and did you mess with the Ktoonze kernel in any way? cause that's what the rom comes with.....
according to the OP on XDA version 9 and up comes with it http://forum.xda-developers.com/showthread.php?t=2774902The touchwiz kernal fixes the rotation issue. There is a link somewhere on this thread.
