Root [Boost Mobile] Uot kitchen question...
Manodedios
Using uot it produced a zip file. Can I unzip and just manually replace the files? I'm asking as I'm using uot to change colors and look and dixias kitchen for other changes and I want to just manually replace the uot files in the working folder of dixias and then cook it.
Have to replace updater binary and edit script...grab the bin out of any warp rom and use their script as an example format
Should be able to...just find the line cwm/twrp is referencing and compare to the original script.
OK I'm confused. Can I take the update binary and script files ,from the twn zip and copy over to the Meta inf .Google/android folder in the working folder?
Lol sorry thought twn was typo...yes you should be able to use it.
I'm off schedule with work and a little sleep deprived lol
After a tip from Shinru, I used the update pair from Shinjitsu and they worked perfectly. If you want to use the ones from Warp OEM (which are derived from Shin's files) be my guest.
As it so happens I'm using shins from. Do I need to modify them or just copy and replace?
