Would this be possible? I have tried to write verizon prl 000001 but had no luck. The phone does not work. I was wondering if you could use roam control to force roaming on boost phones. I will try this once i get home.
some extensive testing has been done with the prevail (also boost) roaming is controlled on Boost's side. changing your prl only allows you to use some additional sid(s) on sprint towers currently restricted on the boost prl
I can almost guarantee Boost is provisioned via Sprint and have roaming blocked. No matter what you do to your phone wont change that. The only thing I've noticed is getting slightly better reception changing the Boost PRL to a Sprint PRL. If you want roaming, may as well sign up with Sprint and get on a contract phone. You really can't expect to get much more for $55\/ w/ shrinkage. Even if there was a way you would probably be cut off from Boosts network for violating their terms and conditions. Technically rooting your device is against Boost's terms and conditions. Am I the only one who reads their terms and conditions? This pretty much covers everything
Our Right To Suspend Or Terminate Services
We can, without notice, suspend or terminate any Service at any time for any reason.
