Would I keep the plan I was on and not have to pay again?I think there have been a few cases of people having to reactivate but shouldn't be an issue if you do. Yea its safe to root. But rooting and installing a custom ROM DOES VOID your warranty.
Yes, nothing changes with any of that unless you change it. I'm on Virgin Mobile and didn't have to reactivate and I'm rooted and running CM 12.Would I keep the plan I was on and not have to pay again?
How stable is CM12? What isn't working?Yes, nothing changes with any of that unless you change it. I'm on Virgin Mobile and didn't have to reactivate and I'm rooted and running CM 12.
Thanks for all of your help!You shouldn't have to do anything. Its stable for me yes. Some people have a few issues like the front camera not working....LTE not working. I don't have any of those. Right now what doesn't work for everyone is NFC and ADB, other then then that its extremely stable for me. I get great battery life..(18+hrs)....strong signals...smooth...just great in general
No problemThanks for all of your help!
Caution on DeCaf Cyanogenmod 11. It corrupted my external SD card. Had to take the card out of my phone and put it in directly into my computer to scan and fix errors and even after that my .apk's and other files were broken. Also after setting up the rom with all my apps, etc. I plug it into my computer to add music to it. My computer could not see any of the storage on my phone. Went back to stock V5. Too many issues on the custom roms.
All i did was setup WiFi and signed into Google Play. Installed the same apps i've been installing for ages with no problems. Ever. That is it. No Xposed. No need for it with a custom rom. Never switched to ART in any of my phones. And root? Isn't this already rooted. I never had to mess with it. After fixing the sd card errors i reinstalled the rom with the sd card out. Then i put the sdcard back in. All was fine after that. So i thought. Except the computer wouldn't see the phone storage. Reinstalled a third time and it still would'nt see the storage on neither one of my 2 computers. I'm just stating what happened to me. Im not dissing your work and I'm not blaming you.Gonna need some proof of that. You didnt say what else you were doing besides flashing my rom. Root, xposed, apps from google play, switching to art, etc all can corrupt an sdcard so unless you can show a definitive link, I'd avoid saying someone's work is shoddy.
Im not mad about it though, I just need to see what happened to see if I actually caused it, and if it was something decaf actually did then what to do to fix it. I'm more than willing to work with anyone who works with me.
The external Sd card is not partitioned. No need for it. It's formatted to Fat 32. Plus the computer wasn't seeing the built in storage either. On the stock roms and the other custom roms on here my computer see both storages on my phone. On both my computers. I'm a new member to this site but i'm far from being new to Android and flashing roms.Perhaps your sdCard was partitioned somehow as a ext2 instead of a Fat32? Did you have link2sd? That would be the only reason your PC isn't seeing the contents is if they aren't on a Fat32. What OS do You run on your PCs?
There is no USB mass storage support on this phone, even with a ROM, recovery, app or OTG, at least not that I could get working. You haven't said exactly how you were trying to pull it up on the computer, so I thought I would point that out.The external Sd card is not partitioned. No need for it. It's formatted to Fat 32. Plus the computer wasn't seeing the built in storage either. On the stock roms and the other custom roms on here my computer see both storages on my phone. On both my computers. I'm a new member to this site but i'm far from being new to Android and flashing roms.
You'll probably have to use another app. Textra is good, but has recently put in unobtrusive ads. Google messenger is another good option.So my question is, if I install the ROM available will SMS/MMS messaging continue to work or do I have to use a 3rd party app to send multimedia messages?
