Root [Boost Mobile] What's the difference between B08 and B08C?
mercury0x000d
The ultra-modern operator
So, what's the difference between the two, anyway? IIRC, I heard B08C was rolled back and B08 is the official current firmware, I also seem to recall that B08 had a slightly louder volume... ?
If anyone can straighten this issue out for me, I'd appreciate it.
There are minimal changes between the two... just a few tweaks here and there honestly... we managed to salvage a B08c update package once and it was only a few mbs and it only altered a few files.... nothing major... unfortunately there are enough changes to prevent you from directly swapping out alot of the critical files... however after you decompile them almost all of the smali is identical
Has anyone ever had the stock music player randomly resume playing of its own accord? Did the B08C update fix this?
Yes i had that problem before and after the update. And i have a few friends with the same problem with this phone. After i started flashing roms without the stock music player it stopped tho. I geuss it has to with the player itself.
