jaymzway
No problem bro. Glad I could help.
I use the ADW EX launcher. It has a lot of themes for it. Many of the other launcher themes will work on ADW too.
Since you are running Carbon, you have access to all of the AOSP themes. Just type in CM11 themes in the Play store. That will give you a lot of choices. XDA also has a theme repository. I would check it out if I were you.
One thing to keep in mind when applying themes is that many will need you to apply the stock theme before the new theme. Some may also require that you change the dpi. I usually don't go to the trouble. I guess it just depends on how badly you want to run the theme. Another thing to keep in mind is that some themes require a cache and Dalvik wipe before they will apply too.
Many of the themes on Play have instructions on applying the theme. Just take a moment to read over the info. :thumbup:
Thanks again for the speedy reply I forgot to add that I wanted to do some homebrew theme's for roms that are out there lmao but that was my mistake however I will try your suggestions as for I'am always up for change and new things to try... It kind of seems like we are alot alike when it comes to modding things we just can't simply leave things alone till we break it lmao..
this will be my 10th phone this year..
