Root [Boost Mobile] ZTE N860 Kernal 2.6.35.7-perf+ztekernel@Zdroid-SMT
czseven
1 click ROOT having Issues ZTEN860 AV2.3.5 SWVN860V1.0.0B10
I have to donate!!! ok i loaded zip for root TWRP, shut off< booted in recovery I see folder says android zip,It contains the right files I use camera button to click it and it promts me to then again click META-INF or SYSTEM or REOVERY. img I click SYSTEM, it then displays four other folders, APP, BIN, ETC, and XBIN, if I click APP, it then displays one folder wich say's, SUPERUSER.APK I click it but it wont let me open and reboot .... do i just power down OR what???
Power down and go back into recovery. The unextracted zip should be in there (I'm assuming you downloaded one of the easy root zips and only moved to your SD card without modifying the contents). Select the install update.zip from your recovery and it will install the custom recovery and root. Reboot after installing and you should be good :)
So power down start in recovery and do install update zip recovery ........ sounds scary to me if the zio isnt full of the right shi** i could lose some good stuff. Anaway can i delete that zip alltogether and get ot start over with one i know is correct... also is there a update today should i wait a few.
PS. Didn't see option with zip and recover or restore in the same sentence in recovery mode.. I can check again but I did not see that so I'm rather get rid of the damn file and start over from scratch because I can open it and see the content in My Files folder before I open zip anything. wait that's what's weird I can go in to my files and I can go to the Android zip file and I can open it up
Yeah... not supposed to open it :o in stock android recovery just select the option to install update... Should be the first option...
Ok last thing when I tried installing it the first time kept going into Docs to Go and I couldn't download it out of there it was locking I look for it there and I look for to my files and I couldn't find it not anything that said zip but I had files that were knew that said clockworkmod super wifi flashlight mod and so . So I started in recovery mode and I searched every single file for that zip file and I could not find it anywhere but why why did I find all those other files and mods today just maybe come in the pact the guy sent me.
Finally rooted will detail problem i was having in detail tomorow.
In short each time i downloaded apps on phone would unzip and spread files. Lol so i finally look ay google drive sure enough there was the untouched zip downloaded it to astro app copyied to mnt/ sd
Started in recovery there it was .. thank everyone that has helped! !!!!!
Thanks my team said I should keep up with everything they are filing via the internet, Everything, well they are keeping ALL if needed so I will comment on this thread. THANK YOU ALL, THE INFO IS A WEALTH OF EVIDENCE, I MEAN INFORMATION. TOODLES.
