Help Boot failure after flashing
Reginar
Good day everyone,
Sadly, I am having some issues with my Motorola Razr (Non US).
So I recently got my Razr back from Motorola after it went into the white light no charging mode. At the time it was still GB, but when I got it back they had updated it to ICS. However, it was stuck in a bootloop and it never actually turned on. Now being the idiot that I am, I used the Razr utility (1.8) with option 1 to 'fix' my phone; resulting in a failed flash. Obviously, my phone is not the US version, so the firmware was wrong.
Now, I am from the Netherlands, but we don't have an official version of the firmware. I suppose that from sbf.droid-developers.org it would either be retail central Europe, or just retail British. Something tells me it would be central europe, as my phone also had the dutch language available, and I suppose the retail British wouldn't.
Alright, so I read up a bit to avoid stupid mistakes like the previous one, and I tried updating with RSD Lite 5.7, after installing the drivers. (Well, I did this before the 1.8 issue, but that aside). I used all three of the central europe versions listed on droid-developers.org, from top to bottom:
SPDREM_U_01.6.5.1-167_SPU-15-M2-1-CEE_1C.91P_0A.6C_RTCEE_CFC_HWp2b_SIGNED.xml.zip
SPDREM_U_01.6.5.1-73_SPU-11-M1-2_SIGNEuropeAustraliaEMEA_USASPDRRTCEE_HWp2b_Servi ce1FF_fastboot.xml.zip
SPDREM_U_01.6.7.2-180_SPU-19-TA-11.6_SIGNEuropeAustraliaEMEA_USASPDRICSRTCEE_HWp2b _Service1FF_fastboot.xml.zip
The first two gave an failed flashing process cdt.bin phone returned fail error. After a bit of searching, I found that this either means that I am using the firmware for the wrong region, or that it is too old. Now, first I thought it might be the region, but then I used the third one. To my surprise, it worked. RSD was able to go through all the steps, up until the rebooting. And then it went into boot failure.
AP Fastboot Flash Mode (s) (Boot Failure)
Invalid CG OTV (CG: cdrom): Invalid SP Data
Invalid CG OTV (CG: system): Invalid SP Data
Invalid CG OTV (CG: webtop): Invalid SP Data
Invalid CG HAB (CG: webtop, status: 0X0056)
Now, googling for this results a number of posts, but they all have the low battery issue. My phone however, is fully charged, and says battery OK. But from here on, I do not know how to proceed. The firmware flash appeared to be working, but the phone won't go beyond the Dual Core boot logo, after that it goes straight into the Boot Failure menu. I can't access recovery either, but I did use the -w command in fastboot to wipe the cache, but that didn't do anything either.
Here comes my very uneducated guess as to what could be the issue. In the firmware file that I used to update the phone, only a few of the files are present that were replaced using the 1.8 utility. So maybe this means that there are still quite a few 'wrong' files on the phone, which weren't included in this update, that have to be replaced by older files. However, I have no clue how to figure out which of these it would be, or if this is even the case. Maybe I don't know what I'm talking about, which is also very possible. I also say this because the old firmware files that I tried to flash first were much (~200mb) bigger than the newest update.
Anyway, if anyone has a clue what to do from here, I'd be very happy to get some input. Sending it back to motorola is something that I want to avoid, as it took them 4! weeks last time I sent my phone to them.
Quick edit: Using the latest version of the GB firmware results in the same issue as using the Central Europe one. However, RSD tools does indeed accept it.
Where are you located? Does NonEFIGS mean anything to you (it doesn't mean anything to me living in the states)?
@fred I am flashing this from my computer, using RSD and/or fastboot.
@Kelmar I am located in the Netherlands. NonEFIGS stands for Non English French Italian German Spanish, which should be the correct version for me. Googling on this seems to support this case, however I have also found a thread
[GSM/CDMA] The EternityProject Official Motorola RAZR ROMs Thread - Page 5 - xda-developers
That seems to indicate that I can use the normal EU.EN firmware instead of the NonEFIGS one, if that simplifies anything.
After reflashing the webtop as instructed in
[GSM/CDMA] How to install an ICS Custom Rom with BootMenu Manager - xda-developers
under fastboot for the webtop, the phone is now no longer stuck in the boot failure.
However, I am where I was before I used the utility, in a bootloop. The phone boots into the dual core screen, goes into the pulsating M screen with the ripples around it, and sits here for a few minutes. After that it repeats itself.
Any ideas on how to proceed from here on?
Using the NonEFIGS instructions linked in a few posts above this one did not work I am afraid, the phone aborted the update when trying to update from the SD card. I could list the exact error if that would help, but I'm not sure this is the way to proceed.
What could help, I suppose, is me finding a preinstall.img as this is not included in any of the SBF's I have been able to find. However, I can't figure out where to find one (a european one, that is)
Edit: Interesting development. If I turn the phone on, it will be stuck in the bootmenu for a minute or 5, after which it turns on, for about a second or 30. It then automatically shuts down. Does that mean anything?
Some new roms when installed for the first time will take a while to boot .....I installed cm 10 xtreme on my u8150 and it was stuck on the boot screen for ages and it wouldn't boot untill I turned it off and then back on again ....even then it still took at least 10 mins
I'm afraid thats not it. I let it boot practically all night, but to no avail.
