printerati
I'm having some difficulty getting a boot sound to play on a rooted Huawei Ascend Plus (M881) that has been flashed to Page Plus from Tracfone. A bootSound.ogg file exists in the /system/media/audio/animationsounds/ directory, but it doesn't play during startup. (It isn't a "silent" file, either...it's a 3 second chime.) I have tried replacing it with one of my own, with no luck.
I have successfully changed the startup and shutdown animations, which are in a completely different directory (/cust/tracfone/us/media) that does not contain any audio files. I copied the .ogg file in there just in case, also with no luck.
Any thoughts? Are there any "properties" I can change anywhere that would enable the boot sound if it is disabled somehow? Thanks!
