Ok guys. I've tried to put this decepticon bootanimation for the past 2 1/2 days. I must be doing something wrong. I followed all of these steps from another forum.
Heres how you load it to your phone...
download this to your computer and unpack and install...Android SDK | Android Developers this is ABD
Once thats downloaded...
plug your phone in to your pc using the usb cable.
on your phone
go to your settings
go to applications
development
check the usb debugging box (it must have the green check in the box)
then swipe down the notification bar
click on the usb connected
click on mount
on your pc
download the zip on in this post...decepticon.zip
open the abd and go to the tools folder.
rename the zip to bootanimation.zip
copy the and paste the zip into your tools folder in the abd
click on start
run
then type cmd in in the box ( this will bring up a black box)
now this is where some people get lost....
Where ever you saved your ABD is its location... when ABD tools folder is open look at the the browser window and copy it. that is its location remember it make a cheat sheet of it cause if you messed p a step you can just refer back to it instead of hunting all over your computer for it.
example mine is C:\Documents and Settings\Administrator\My Documents\Downloads\android-sdk-windows\tools
In the black bock type cd then the location of your tools folder..
example...cd C:\Documents and Settings\Administrator\My Documents\Downloads\android-sdk-windows\tools...
Then hit enter
then type..
adb push bootanimation.zip /data/local
it may take a second, then it will show in the black box that it had downloaded x amount in x amount of sec.
Then you can unmount your phone
Turn off your phone
then restart it...
enjoy your new animation
I tried this like 35 times no exaggeration. I downloaded this zip file decepticon_1.03.zip . Im not going to give up until I have this bootanimation on my phone. If you guys can give me a little assistance or possibly point out what im doing wrong, or even just give new direction i'd REALLY appreciate it.
on your phone
go to your settings
go to applications
development
click on mount
on your pc
click on start
run
Then hit enter
then type..
Turn off your phone
then restart it...
