Using Rooted Samsung Proclaim:
(I have used both of the root kernels and the stock kernel)
I've read multitudes of online problems involving bootloops. I've even fixed one of my own a few months ago using adb. (In that case I renamed the framework-res.apk file because I was messing around with changing the emoticons, this turned out to be a terrible Idea, but easily fixed after about 12 hours of frantic trial and error.) I learned that ADB is quite awesome.
Anyway, I recently used System Tuner Pro to boil the stock Video Player after installing and uninstalling a few video players from the play store. I like to freeze most stock apps to see whether I really want to use them or not. I didn't pay attention to the toast which warned me that I might need to reboot for the change to take affect. So after I couldn't find the Video Player in my apps, I boiled it again. This time noticing the toast warning. So I rebooted. Now I'm stuck at the bootanimation loop.
I can still connect with adb from the bootloader and during the bootanimation loop. I have pulled most of the system files and have removed the VideoPlayer.apk file thinking the double boil had something to do with it. Still loops.
I've tried reinstalling the framework-res file that was still on my computer from the last time I had trouble. It installed just fine but still looping.
There must be some unresolved conflict during the bootanimation but I have no Idea which files to replace or reinstall. I have even wiped everything using the factory reset in the bootloader. I have attempted to wipe with adb but this always seems to give failures and permission troubles.
I know this is a long description, but i have searched, read, and tried for a couple days now and nothing seems to fit my specific problem.
Any Ideas?
Any Ideas?
