After running Absolution for a couple of weeks, I was missing some of the Sense stuff so I flashed Android Revolution. I like it a lot. I got back the things I like with Sense, plus the 3.0 lockscreen and CRT animations. It may not be as snappy as Absolution but it's not so slow that it's frustrating. It's the same as I had gotten used to with stock. Battery life has been excellent; on par with what I was getting with Absolution. I've been able to find mods to change pretty much everything I want (5-bar signal, H+ icon, transparent notification background, wake w/ volume-key). And the best of all, it's the first ROM I've tried so far that consistently gives me mobile network speeds that are FASTER than what I was getting with the stock ROM. I was getting around 650-700kB/s w/ stock. CoreDroid dropped to 350kB/s. Absolution was around 475-550kB/s. With ARHD I'm getting around 900kB/s! Yeah that's no where near the LTE speeds, but LTE isn't available in my area. I'm thinking that's about as good as it's going to get for me.
So as of right now I'm really happy with my ARHD setup. Probably gonna stick with it for a while.
I thought I was ready to try a ROM, but I started looking through the Revolution forum and saw issues like "tinny sound" etc. Right now I don't have any complaints with my phone. Part of that is because I've only had it for a week. Before that I had an LG Thrive...this is a huge improvement in speed, memory, screen size, etc.
So far the only thing I can think that I would want different is the battery life...although I might be able to use JuiceDefender to help with that somewhat.
I also saw that you wrote something about flashing mods. I'm assuming that is to change some of the modules of the ROM. I also assume you flash that basically the same way you do a ROM...but without wiping everything.
You have been extremely helpful. I've been reading the forums and quite a few articles on Addictivetips.com. I think I know more about the Android setup that I did using my Thrive. Having a background in Linux has been helpful because quite a bit of the terminology is similar. I'm just not familiar with the phone side of things.
Since you're fine with how the stock ROM is working for you, maybe you should continue using that for a bit so you know what Sense has to offer. Then instead of going to another Sense ROM, try out one of the non-Sense based ROMs. Cyanogen is pretty much the standard for that. Absolution is also a really good one. Personally, there are some things in Sense that I really like, that's why I settled on ARHD after trying out Absolution. But you may discover you prefer a more pure Android experience. And if after trying out different ROMs you decide the stock ROM works best for you, you can always just restore your backup. But then at least you'll have a clearer picture of what you want out of your phone.
