Help Bootloop after editing build props file
combat22
On my Lenovo A5500-H after editing build props and restarting my device it get in to bootloop. (Usb debugging is set off / custom recovery not exist for my device) When i wipe cache and do factory reset it will still stay in bootloop. :( So how to fix it? :(
Yeh, definitely needs to re-flash, no other fix.
Possibly might be correct firmware here?
http://lenovo-forums.ru/forum/281-lenovo-tab-a8-50-a5500/
Can you read Russian? Good luck. :thumbsupdroid:
Once you've got a ROM, usual method with Lenovo is to dump it onto an SD, go into the phone's recovery and select flash with ZIP I think.
BTW not much luck on XDA Devs for this thing.
http://forum.xda-developers.com/general/xda-assist/lenovo-a5500-h-firmware-t3140782
And this is a ROM for the Chinese version of this device.
http://www.romjd.com/Device/lenovo-a5500/hot/all/1
But you can't download unless you're in China, and might not work anyway.
