I think it was made for 2.3.2 therefore you will bootloop. Try stock recovery (Pull battery, put it back in and hold power and "x" on keyboard, wait for ! Then press magnifying glass on keyboard) then wipe cache and wipe data then hit reboot system.
Try holding the up arrow key on the keyboard when powering it on. That should put you in bootloader and you should be able to see it in RSD Lite. Should be able to SBF from there.
aww man i really ****ed my phone up now. the screen stays black and its not recignized in RSD lite anymore but the little LED lights up (the one next to where the micro USB cable plugs in) when i have it connected to my computer
