Root BootLoop tried the unbrick guide
hheen
Well my phone is in a bootloop, need help fixing as the "{UNBRICK} guide didn't work so any idea's? It used to have cwm but as i flashed it back to the stock rom the root and cwm is gone. Also thank you for reading this. :)
This is how I recovered:
1) Turn on the phone and connect it to your PC/laptop
2) While phone bootloops, open un command prompt on pc and type, one line at the time, but be quick to do that between bootloops:
adb shell
reboot recovery
This will reboot phone in recovery mode.
3) From there, delete data and cache, and reboot
4) You're done! You will also be completely unrooted, even to that LG software which monitors root :)
Correct...another way is by fastboot reboot c:/recovery.img
Make sure you have always a copy of your cwm recovery image in your pc
