McLovlein13
to start, im not a rookie when it comes to rooting, but i am when it comes to rooting motorollas. the razr was the first ive done. i was using bootstrap for a while just fine, but then i found a rom that required i use safestrap. i have no idea what the difference is.
i downloaded the safestrap apk and installed it then opened the app and installed the recovery. i powered off the phone to see what the differences were and it eventually brought me to the screen that says [menu] for recovery and [search] to continue. if i push menu, it takes me to a screen with the clockwork mod sign in the background and no words. i can push power from there and it will bring me back to the beginning of safestrap.
if i push search, or let it sit for like 10 seconds, the screen goes completely black. i noticed it is on, because i can see the infamous blotches that the razr has, but the screen is all black.
i just need to turn the phone on, i know what to do from there... any way to do that? i dont care what it takes
