Root bootunlock help
Hendoe
ok well prior to this i used htcdev already. Doesnt work for me cause it says i need to upgrade to 1.00.1550.07 then it tells me to go to my phone and upgrade from there...but im at 2.00....how the hell do i down grade from 2.00 to 1.00.1550.07....i dont get it...i know how to follow instructions but this makes it impossible for me to do so. cause i cant downgrade on a upgrade button.. ??? :confused: i got this from a nother post please help goros
Try flashing the ruu for your phone. Make sure it's the right one, that should get to where you can go to htcdev and unlock. Make or have a backup available, just in case.
i did use the right one i used the metro psc... seems like i need to down grade the system...... thus y the error poped up
