Help Bought and downloaded Astro Pro but nothing on device
androidexpat
I can see it under settings-Applications-Manage applications and under downloaded but nothing allows me to open it on my Nexus S:confused::confused: I also have color note and can not get that to open as well :confused:
It sounds like you didn't enable unsigned applications to run. Go to settings>app settings and check Unknown sources. I'm assuming these are apps you downloaded from somewhere other than the Market.
Astro Pro is one of those it's only the license deals, not launchable. You have to have Astro installed as well, and that's what you open. I've got Pro and I don't see ads when I open Astro so it's working as expected for me.
Many thanks for the kind reply. You are right about this. I did not know one had to download the regular ASTRO as well. I had only downloaded ASTRO PRO thinking it would be better without the ads. ASTRO is working fine now.
