BR player
SirSpace
Is there any player that will play blue ray files. Mx player won't do it. Actually it won't even open the files so do they even have an app that plays br movies or am I beat lol
If you're just copying the files from a Blu-ray disc, it won't work. As chanchan05 posted, they have to be properly ripped.
Commercial Blu-ray content is likely to have DRM copy protection as well.
I am just wondering why don't you just properly rip the blue ray so you won't have a problem? I have blue ray quality videos that play fine using Dice Player.
Cause I don't have the files myself my friend let me download it from his site. I thought about that but even if I didrip the files myself I would still need a player to play it on my phone.
Lol I know they play well on dice player but when I searched dice player on play store dice player doesn't come up :(
Thanks chan but how come its not there when I use play store app? And yeah my buddy is a computer programmer so he knows his stuff. Its just the players keep saying does not support video file so that's why I wanna try dice. Thank you though.... its saying its not compatible with my device :( now what?:/
Forgot Blu-Ray, no phone os will play raw dvd. vob files either, optical media have particular structures, they are not just a simple digital media file, and this is totally ignoring the encryption that's involved. Optical disks whether physical or iso's have to be converted into a compatible format before it can be decoded and played on your device. Without getting into the decryption aspect after the disk has been ripped into a digital format you still have to convert it into a file format that is playable and formatted for your particular device. Once you have the digital source ripped then using something like Handbrake to convert it leaves you with a file that's finally playable on your phone.
Lol this just got complicated ill ask him to convert to DVD cause they play on my phone. Thank you all for the advice
