agreed, i just played this game last night. hold the home button and the power till you get the reboot screen. wipe everything, yes it sucks but it works out in the end. once your back to totally stock settings, download z4root run it off the sd card, once that is done, download the 2 part 2.3.3 files, i can't remember where they are located but poke around the gingerbread update sites and you'll find it. MAKE SURE YOU GET BOTH PARTS! once you have them download bootstrapper fro the DROID 2! not droid x, download and install, run it and install both parts before you leave the recovery. then your all done! rooted gingerbread
