Help Bricked atrix 2 please help
TCA4000
I tried to downgrade my OTA ICS back to GB. It failed and now my phone is bricked. Is there anything I can do to fix it?:(
It had been said that you either have to take it back to Motorola to fix, or you can buy and try the Motorola USB developer adapter and pull the battery and try to reflash it back to stock. Although I have yet to hear of someone actually succeeding.
Has far as I know once you upgrade to the ics leak 2 or the ota ics update you are stuck as of right now.
I just found saw this.
http://forum.xda-developers.com/showpost.php?p=32921904&postcount=387
"Which version of ICS was your base? That being leak #1, leak #2/soak/"official" OTA.
If you are on anything but leak 1, you can not fxz back, then OTA to ICS again. If you are on leak 1, you can use my script in the dev section to go back to GB and install leak 1 again.
About the ONLY thing you might be able to do, if you are on leak 2/soak/"official" OTA, is to restore a backup of the stock ICS system partition, that you took with CWM."
Thanks for the reply but I was on the official OTA ICS update. I can not even turn the phone on at all...press the power button and nothing happens...I think I am truly a BRICK holder...lol...NOT SO lol
I think I will try to take it back to Motorola or is it possible that AT&T will re-flash it for me?
