bricked droid 2 global
  • Thread starter Thread starter luckman
  • Start date Start date
L
luckman
Guest
My motorola droid 2 global isbricked. At first i flash my phone with RSD lite, and succes to flash it. But at second, i flash again my phone, unfortunately.....................
Bootloader
Do.11
Err:a5, 70,70, 00, 1F
NEM_WAP BLANK
Service req
If the first flash was a success, I don't know why you would want to flash it again.
I _think_ you should be able to get the missing info (either for the second flash or the reason you flashed a second time) by calling *228, wait for the prompt and select either option 1 to re-activate it or option 3 to also reactivate it on your VZW account.
If it is stuck on the bootloader screen, try pulling out the battery for about 30 seconds, then replace it, power the phone up and do the *228 things I mentioned above.
good luck
