Root Bricked htc magic. PLEASE HELP!
eli_88
I've just bought a new htc magic in china and got to rooting it.
first I installed the recovery-RA-hero-v1.6.2 and all worked fine.
I tried installing a different recovery - recovery-RAv1.0H.img.
After that, my magic just goes on rebooting itself after the "HTC Magic" logo.
Nothing seems to work (power + volume down, power + home) - it just keeps on rebooting.
The only thing that does happen is when I hold the trackball the moment it boots. the light near the speaker turns blue and the phone stops booting.
Please help....:confused::confused::confused:
Eli
hi i dont know if u got your problem resolved as yet but, the same thing happened to my phone while trying to install and update. Try the hard reset it fixed my problem
Instruction: To reset the HTC Magic phone using phone buttons
1. With the phone turned off, press and hold the HOME and BACK buttons.
2. Briefly press the END CALL/POWER button while continuing to press the HOME and BACK buttons.
3. When you see the screen with the 3 Android images, release the HOME and BACK buttons, and then press the TRACKBALL.
