Help Bricked Phone After Failed Encryption
Ekkoze
Hello, I just recently attempted to encrypt my rooted phone and after 2 hours of a constantly looping animation I Googled how long it should normally take and saw people saying 10-30 minutes but the phone said an hour in the warning. After noticing it getting ridiculously hot and not turning off and back on I decided to turn it of using the power button. Now whenever I turn it on I get the JFLTE Dev Connection Team opening animation with the blinking LED then it says "Android is starting...." then it comes to a screen where it allows me to enter my pin and an "Emergency Dialer" option that takes awhile to load in properly. Then when I correctly enter my pin I get to the JFLTE Dev Connection Team opening animation without the blinking LED and it stays in loop. Please help!
If you can get into Recovery you can try to clear cache then reboot.
Factory reset from recovery if clearing cache doesn't work.
Reflash firmware and start over if above fails.
