Root Bricked phone need help!!!
zstruzi
So was uploading the new rom and I forgot that the rom I had up couldn't read the sd card, so I wiped everything and little did I know my backups I had couldn't be found and now im bricked. I cant access ftm mode and that's my big problem, if anyone know how I can unroot it to access this it would be great. and another problem is my computer doesn't read the files on it so I cant put anything in the sd card. ty and sorry if I missed something
It sounds like unrooting is the least of your worries right now lol
1. If you can boot your phone you can probably fix it.
2. If you can boot into cwm recovery you can probably fix it
3. If you can get adb working on your phone in the rom or in cwm you can probably fix it.
I try to boot my phone and it wont boot, I cant find any files in cwm and it wont connect to my comp bc it wont start up, and I don't know how to work adb lol
pull the sd card and put it into your pc then put a flashable rom on it. Put the sd card back in and try to flash it from CWM
that or cwm also has the ability to connect to a pc at the bottom of the "mounts and storage" menu. and roms wipe system for you when you run an install so rule of thumb is DONT WIPE SYSTEM unless you know exactly what youre doing
