Bricked phone / Orange RUU HELP please!
I have just run AlphaRev S-OFF CD and got to step 3.. it seemed to be taking forever and i disconnected it but now the phone wont boot.
I didn't take a nandroid backup and all the RUUs i try to put on have CID error displayed.
Can anyone tell me how to fix the phone / get the correct RUU please?
You can't get the correct RUU as it doesn't exist.
Either make a goldcard or use the GB 2.3 RUU
There is no orange one.
I hope you made a gold card because as far as I'm aware you need to flash a generic RUU with (not 100% sure on this bit) the same version you were on.
For example if you got the phone on 2.2 (Froyo) that's what you need to get. But like I said I ain't certain on that last piece of info so ideally get someone with more knowledge on the matter to confirm if it's correct.
Hope it helps a little.
Ahh Dan beat me too it.
Thanks guys
Can you link the correct RUU please? I have tried loads but none are working..
Also if i can make a goldcard then what do i need to do?
There is no correct. It's either goldcard (then any RUU works) or gingerbread from htcdev.com - kernel source - view downloads
