Root bricked quattro with build.prop
zzyzzyzzx
Hey,
So i managed to brick my phone with a build.prop (forgot to change it back to the original one after i tricked market into thinking i had an s3 for snapchat) and now my phone will boot up and everything, but after the metro splash screen, i get black, and if it sits long enough turns white.
I have been trying to ADB but my device never seems to show up under adb devices, no matter what i do i have tried placing it in calibration mode in hops to adb pull /system/build.prop.org_bak then push it back in but the device not showing up in the list is killer, i dont know what else to try, and i need my phone for work =/
ps. sorry was not sure if this should go in the root section or not, if its in the wrong section im sorry
u have to use the tool in the unbrick guide to push the file back adb push seams to not work properly.
if adb works on boot maybe adb should be able to save yu.
