filoktitis
hi to all..
i am new to develope a smartphone,so i guess i messed it up...
i have a zte blade with a default rom android 2.1..ive made a succesful update to android froyo 2.2 and then i had the brilliant idea of rooting my device installing custom roms,busybox etc...well..i rooted my phone temporarily cause the permanent root doesnt work temporary root says that after phone reboot the device is not longer rooted)...i used the z4 apk to do that...superuser was installed as well as busy box...i downloaded the cyanogenmod 7.0.3 stable without the google apps and then flashed it...clockworkmod recovery was running and installing the new rom...everything seem ok..and then my phone reboot the green android little man was there and then the image of the blue android little man skating...i thought i made it but instead of booting normally the blue android skating little man keeps appearing on the screen and it doesnt boot at all...i think i brick my zte...i found a solution in a forum that says push the volume down button plus the poweron button together to start the clockwork recovery mod...i did it but there are only the basic options there and nothing more...no secondary oprin like usb mass storage...i guess tht is because my phone its not rooted yet since reboot after cyanogenmod installation....so....here i am...what should i do now in order to fix this bootloop???any suggestion????plsssss????
thx!!!
)thx!!!
