Broke screen?
They are all the same. Only difference in some is the color (obviously) and some don't have the touch buttons included (means you have to pull the ones off your old screen without damaging them ( even had to do this with the whole replacement screen mentioned later). I tried doing this to my wife's and only had a square inch left and cracked the LCD cause I didn't get it hot enough to loosen the glue. Ended up having to buy the whole replacement screen on ebay for $160.
