Broken power button - need screen lock + keep awake.
dog812
So i have a older nexus 1, i am trying to wait out my contract before i get a new phone.
My physical power button broke. So if the screen goes black i have not way of reviving it besides pulling the battery, or plugging it into the wall.
I downloaded a keep awake app, but now when i put the phone in my pocket it hits buttons , makes calls, etc...
Is there a app that will lock the screen while it is awake? And keep it awake?
OOps i meant nexus S , but same thing.. one physical button on the side for power, Physical volume buttons, then 4 soft buttons along bottom of the screen.
3
Cool. if youre into rooting you can just use one of the other buttons to wake the screen. Simples :beer:
A lot of the custom roms let you use the volume button to wake. Im sure theres root ways to do that without even flashing a rom. Something to look into man. All the nexus have great developer support :thumbup:
Try Gravity Screen. You don't need to be rooted.
You can set it up to wake the phone just by picking it up. You can adjust the sensitivity.
Also, you can set it up to sleep by just putting the phone down or in your pocket.
There are tons more apps that will wake your phone.
yup, i think theres actually one called Shake To Wake.
All these apps seem to be heavy on battery though
I see you found something that works, but for the record Auto Screen On lets you wake the phone with either shaking or the proximity sensor (either one or two taps to wake). I use it and haven't found it to be much of a battery hog.
Tap Tap App ( Screen On-Off )
Pedro Maicas - July 5, 2013
Tools
Description
Lock and unlock the screen with a double tap the proximity sensor.
And widget, locks your phone with one click.
Reduces use of the power button.
Turns off screen fast.
You will not find a better program than this to lock and unlock the screen :-)
It works ! See videos:
Or search youtube: "tap tap app for htc desire hd"
User say:
First & Best This is the very first App on Google play to utilize the sensors for on and off functions. Has been developed many years ago. All other apps are made after this one. And I have been a big fan of it since it's creation. Plus it just WORKS. Simply
All I can say is THANK YOU!! I just place my hand or wave it near the top of my phone and it goes to sleep....and when it's asleep (black screen) I just place my hand or wave it across the top front and oila! It wakes up! Thank you for taking the time and your skills to create this app for android peeps. It's MUCH appreciated! TEN STARS!!!
If you mean Auto Screen On, I tried that and left a comment:
Actually Works, But... I performs just as advertised. But it’s currently using 53% of my battery, way more than display, at 20%. So it might have to take a hike, which is a shame, since it’s the only screen waker that works on my Ascend ll.
But I shall try it again...
Okay, reinstalled it. Applications > Battery Use says:
04% Cell Standby
03% Display
02% Phone Idle
91% Auto Screen On
That sure looks like a problem to me, but actual numbers from SystemPanel say it’s only using about 10M, like most of the other running apps on my droid. So I’ll keep watching.
Meanwhile, the aforementioned Power On Volume does not even show up in the battery use percentages* and reads about 11M in SystemPanel. So I have no idea which is better, but I’m certain which I prefer. Besides, it’s easier to press a volume button than to wave a magic wand.
*It used to show up there, to the point that I discussed it with the dev and ultimately uninstalled it, until this thread rekindled my curiosity.
