power button is strip type not button type. not able to get spare is there any way i can turn it on . I try some method to connect usb charger without battory and pressing power buton phone up side down nothing worked please let me know any other way to turn on ,it shows charging screen when i plug it to charging
phone is not turning on, yes i Have turned on the ADB debugging on before it switched off _
getting the charging animation when i connect the phone to charger or to PC . so then how can i turn my phone ON via ADB or uisng any tool which works on ADB. Please let me know the proceedure
i did flashed custom rom . Its not power on after flashing need to power on using power button, Is there any custom rom which power on the phone after flashing
