Apps Browse picture
Chikabala
Hello,
Please how can i browse a picture from androidphone or from SD card and put it in a listView (Android)?
Thank you
You can use the Java File API to iterate all files starting from a given directory (e.g. /sdcard) recursively. The API call to get all files in a folder is listFiles.
You can add a file filter (implements FileFilter) to filter out all image files. E.g.
public class ImageFileFilter implements FileFilter {
private final String[] imageFileExtensions = new String[] {"jpg", "jpeg", "png", "gif", "tiff"};
public boolean accept(File file) {
for (String extension : imageFileExtensions) {
if (file.getName().toLowerCase().endsWith(extension)) {
return true;
return false;
You need to add this filter to the listFiles call, e.g.
File[] files = dir.listFiles(new ImageFileFilter());
Once you get all the image files you want, you can add those files to the ListView using something like ArrayAdapter.
Hope this helps.
Shengxin
Apps: Secret Locker
There is also a class called FileFilter that does a lot of the work.
One thing to watch out for: when decoding bitmaps from a byte stream (file) be sure to only decode the size you need. Otherwise you will hit OOM (out of memory) errors very quickly.
I forget some of the code off the top of my head but I think you use something called a BitmapObject and set it to inDecodeBounds. Then you can get the proportions of the image and decode a down-scaled version of the image.
I think there's a lot on stackoverflow about this but if I get the time I'll post some links and code.
To expand on what alp said, your app (application in general, not each activity) is.only granted a 20MB portion of the devices total memory to work with at runtime. Memory management J's extremely important in the mobile space.
