Bugs and fixes for U960
that is not my rom... try my rom and install the update and see if it is not working ...
yup great!
thx
but how bout this v6supercharger?
does it work on your u960?
I always had to enter numbers between 1 and 30... then it said 25% supercharged... then again enter a number between 1 and 30 ... that made to 50% supercharged... but then again it repeated the 25% step mentioned above and I was "caught" in an infinite loop that was always asking for numbers bwtween 1 and 30....
but I have no clue which numbers to enter there and what they are for...
yup great!
thx
to install V6SuperCharger you must use this options:
Scrolling speed Option: Choose 1 fast
Integration build.prop: choose option B integrates with build.prop
Init.rc Integration: Integrates with init.rc choose option Y
Disable Animation AWESOME V6?: Select Y to disable
Select menu item 10 to perform automatic configuration
SuperMinFree Calculator Apply Settings? Choose Y to enforce
At the end choose option 30 to exit and restart the terminal to complete the configuration.
After the restart, wait 180 seconds and run /system/xbin/v6sc.sh to verify if the configuration properly gives "100% Supercharger"
Hello i just go my zte u960 but i can't get my data to work i'm on 3g uk network i got the setting fom them but nothing is happening, anyone got any ideas what the problem could be. Thanks
You have to choose the sim you want to use for data, and set the apn in the settings menus.
That's all.
