Root build prop deleted
Zeusking
Hey...i deleted build prop file from my lg l70.....n its shows blank screen after reboot.... Wat do i do?
Plz reply fast
Welcome to our AndroidForums, Zeusking!
I've moved your thread over to our all-things-root area for the L70 for you--the folks in here should be able to help you best.
Cheers!
Zeusking,
1. Do you have a custom recovery?
2. If yes, do you know how to use adb?
3. If yes, can you point me to the ROM (stock or custom) that you'd like the build.prop file from?
-SA
