ipoke smot
Depending on what build.prop editor you use, they are automatically listed alphabetically. For instance, ROM Toolbox places them with the other ro.lge items automatically. As far as the sd partition is concerned, this only works with apps that are allowed to be moved by android, but link2sd makes it where you can move just about anything. If you still want link2sd to work with those apps, then do not delete partition. The wife hasn't had any insufficient storage issues yet and I have not set up link2sd on her phone ever. I've only added these two lines.Do i assume these go at the bottom? And also should i remove the partitioning of my sd card, makes sense considering as it wouldnt be necessary, including link2sd or foldermount
