Apps Build Target problems
Patrijs
Hey all,
I'm new to android developping. I installed both the SDK manager and Eclipse, but when I'm creating a new project I can only choose Android 4.0 as a built target. Everything works well on AVD but I can't debug on my HTC Sensation (since its API lvl is to low ofcourse...). Anyone an idea on how I can fix this and thus choose another Android platform while creating a new project? (I did install all of the Android versions in SDK manager).
Thx!
Patrijs
In Eclipse, right-click on your project, and choose Properties. In the project properties window, choose Android on the left and the choose the Android target that matches the version of Android on your HTC Sensation.
Also in your AndroidManifest.xml, check that the android:minSdkVersion and android:targetSdkVersion attributes of the uses-sdk tag are lower enough.
Edit: Sorry. When you're creating a new project, just select the Android version you want in the Select Build Target screen of the New Android Project wizard.
