same research ive been doing. Dont get ur hopes up too much about getting it done soon tho. Building cm is usually not an easy process, and will more than likely require a lot of trial and error. Best of luck tho, man! One suggestion tho.... If i remember right, u had said that u no longer own a Venture. U might wanna look into picking up a cheap, "beater" venture to test on before releasing any form of a beta version. Building cm is an intensive process that could easily hard brick a device, and we dont want anyone around here bricking their phones. If u end up coming up with a build u feel good about, send it my way privately before releasing to the public. I will see if i can get it to run thru an emulator first, and then if all looks good, ill try it out on one of the ventures i have lying around. Best of luck bro. Im excited to c what u come up with!
Dont leave this project dead in the water if u r having trouble figuring it out on your own! I would love to see u succeed at this project! Keep us updated! Oh, and if u post all your source code to git, it would make it a lot easier for us to review as a community, and help figure out where any errors r being made
im rootin' for ya!
other phones I found didn't even have custom roms.
ill check it out in depth tomorrow. I should have been more clear tho... When i said msm7x27, the "x" is a variable... I kno off hand that there is an msm7227 chipset, possibly others. So any chipset that follows msm7x27 with the x in that being a variable, i would b interested in knowing about. There isnt actually a chipset named msm7x27.
