Business Mileage Tracker
I know there are several out there, but none seem to fit well.
Here's what I'd like in a business mileage application:
> Uses GPS
> Continues to run in the background w/o affecting other apps.
> Super simple user interface : START (green) and STOP (red)
> Saves logs to the sd card
> Log includes: starting time & address (including gps coordinates); trip complete time & address; tempoarary stop times & addresses (this should be automatically detected with a user pre-set minimum movement over time period function ie. >500' over 10 minutes. And when detected an audible alert with a selection prompt to continue recording or to stop. Also a pre-set menu choice for this alowing either auto stop or continue with no selection selection at the prompt.); and a trip map.
> Upon trip completion prompt for type of trip; business, commuting, or personal and a generic label option.
I'm not sure of the type of output log, but it would be necessary to compile a years worth of mileage for the the three different types of trips. This number should closely match the actual odometer mileage if the program is used consistantly.
Let me know if there are any out there like this that I've missed.
Or maybe a developer could build this one.
Thanks,
Clint
> Uses GPS
Thanks,
Clint
TripLog is the BEST of all! 4.4 out of 5, 100,000 installs, and download FREE!!!
Website:
www.bizlogapp.com
